1991 Ford Sierra Ghia Front right fog light not working.
Old Feb 9, 2022 | 04:01 PM
Bren1977's Avatar
Bren1977
Default 1991 Ford Sierra Ghia Front right fog light not working.
Checked loom connector from fog light to connector on loom - it works as does the bulb when plugged into the front left hand side connector.
however, rhs front connector even when connected to fog light retains 4.99 Volts when lights on and fog light switch pushed on.
lhs front provides 12.59 volts.
I’ve checked the earth points behind the front headlamps but despite removing and cleaning/sanding the earth point I still can’t get the fog light to work.
presuming it’s shorting to earth somehow but has anyone else seen a similar occurrence and if so what did you do to fix it?
Old Apr 18, 2022 | 07:57 PM
Bren1977's Avatar
Bren1977
Still trying to figure out the issue with my wiring as replaced both fuses and the white relay and still no front right fog light.
can anyone please assist if they have ever had the same issue and if so how did they rectify the issue?
Old Apr 19, 2022 | 06:51 PM
ray barker's Avatar
ray barker
hi there run a new earth wire to it from the battery negative for illimination. or take a live feed from the fog light that works to the one that dont
Old Apr 20, 2022 | 09:42 PM
Bren1977's Avatar
Bren1977
okay ill give that a try Ray thanks for your help I’ll give it a shot to see if it works but still the strange thing is why it stopped working all of a sudden.
just have tk figure out also why my abs is acting up despite having replaced the abs-controller/servo unit too still getting locking of rear wheels 🛞 and brake pedal going rock hard then back to normal.
strange gremlins out of the blue
Old Apr 21, 2022 | 08:06 PM
ray barker's Avatar
ray barker
the problem is there old fords i have one too. when there not used for long periods it dont do them any good i left the battery disconected on mine for six months for some reason it took the heater motor headlight switch and shagged part of the fukin fuse box try understanding that. mines been of the road for the winter and now my abs light is on ive not touched the system i did do some grinding close to the front discs im hoping to clean the sencors and abs rings hopefully should sort it.theres fuses also for the abs i will checking them also
alansST
Apr 17, 2020 01:30 PM
alber1956
Feb 4, 2015 02:16 PM
Sideways_Susan
Nov 6, 2010 07:47 PM
borgie
Ford Mondeo Including ST
Feb 19, 2010 07:41 PM
