Hi all, does anyone know where I can find the tool to remove the crank pulley on a YB? There was a copy of the Ford type tool around a couple of years ago for 10-15 GBP but I can't seem to find anyone making/selling them now, now I wish I had bought it back then lol. Any insight would be appreciated ☺️
Undo crank pulley bolt so it extends out beyond the pulley.
use thick sheet of steel with 3 holes drilled in the same pattern as the 3 threaded holes in the front of the pulley, then use 3 m8 bolts to pull it forwards.
I didn't think of that, thanks mate, that should be pretty cheap to make as well
