Electrologic problem
Old Jan 11, 2022 | 12:00 PM
georgeps21's Avatar
georgeps21
Default Electrologic problem
Hey there. I f*cked up!
I really need your help guys!
I have an old Ford Fiesta MK4 from my grandparent. I decided to change the radio player to a newer one. I have some electronic knowledge about stuff and I didn't think I was gonna have any problem.
I facked up though while i was trying to put a connector on the 12V cable that constantly gives power to the radio (for memory) and in my case,I it gives power to the clock and all the internal lights. I touched the aluminum housing that the player was supposed to go and it did an arc Welding before I even had time to pull it. The 'welding' stopped and I thought it would be an easy fix by changing the fuses.
The problem is that all the fuses seem to be fine, Both on the driver's side and on the hood. I checked all the 3,5,10, 20 ones, and most of them also for continuity. I even changed the 4th fuse that seemed to power the clock and the lights. I am thinking it might be sth on the cable or I screwed it up big.
While checking Resistance between Ground and that orange cable I am measuring 120 Ω so it is probably connected to somewhere...
Any tips? Any ideas?
The fuse boxes:
https://knigaproavto.ru/shemy/en/for...x-diagram.html
Here is the spot where the cable touched.
just a photo of the storm.
Old Jan 11, 2022 | 10:20 PM
georgeps21's Avatar
georgeps21
it was a fuse. I finally found it
markie t
Apr 28, 2017 06:32 PM
tker57
Sep 13, 2010 07:01 PM
ballin
39
Jul 23, 2008 07:08 PM
rst230bhp
Jul 15, 2006 11:23 PM
Danny B
Oct 27, 2005 11:11 PM
