Ford Mondeo S220 -02 Starting problem.
Old Nov 9, 2021 | 09:33 PM
lattunee's Avatar
lattunee
Default Ford Mondeo S220 -02 Starting problem.
Hey everybody!
I just bought my first Ford Mondeo S220 3.0 V6.
First i checked that the startermotor is gone.. then changed new startermotor and trying to start but car dont say anything. Starting normally but not fire up.
Im checked all fuses, relays and battery have power.
Then i realized that there is no spark coming. Have anyone same problem?
With normal obd tester i cant read any codes. Maybe immobiliser is on? Not anything leds blinking in clock or speedometer. Pleasw help
Old Nov 10, 2021 | 06:34 AM
oldford's Avatar
oldford
Maybe (very big maybe) it's the crankshaft position sensor.
If the engine computer cannot determine that the engine is cranking it will not fire the plugs.
Can you read live data? Do you see a rpm when cranking?
Old Nov 10, 2021 | 08:45 AM
It could also be an immobiliser fault. Do you have any spare keys you could try.
DannyL
Jul 6, 2011 12:45 PM
martins86
Aug 25, 2006 07:17 PM
Snowflame
Mar 29, 2005 02:30 PM
Sunil_FiestaRS1800
Feb 4, 2005 08:19 PM
