Boost issue
Old Oct 22, 2021 | 11:14 PM
Birdsfocusst225's Avatar
Birdsfocusst225
Birds st
Default Boost issue
Hi all
I’m looking for any help on the issues I’m having with my 2007 focus st.
The car under full load drops and picks up boost in waves. Also when driven slowly/normally warming it up there is hesitation going up the revs like what little boost it’s getting is still being taken away.
Please any ideas on what to do next would be greatly appreciated as already done maf sensor, boost solenoid and pressure test and coming up with no answers
cheers in advance
Old Oct 23, 2021 | 08:43 AM
cossie2's Avatar
cossie2
Did you tried diagnostic if any fault codes appear?
Old Oct 23, 2021 | 09:19 AM
Birdsfocusst225
Birds st
Hi
yes had it plugged in on Thursday it came back with knock sensors but deleted and not returned I was told they could have been triggered during being worked on previously but unsure if that’s accurate?
im having no engine management lights up etc
Old Oct 23, 2021 | 04:19 PM
cossie2's Avatar
cossie2
...Check one more time turbo actuator .and wg port for easy movement......
Old Oct 23, 2021 | 08:40 PM
Birdsfocusst225
Birds st
Sorry what is the wg port? I can have a look at the turbo actuator but is there anything to actually look for?
Old Oct 24, 2021 | 09:07 AM
cossie2's Avatar
cossie2
Wastegate is a valve that controls the flow of exhaust gas from an engine to the turbocharger..Actuator rod is connected to it...Maybe it is js just stuck or actuator is not properly keeping pressure due to age..Worth a try...
Old Oct 24, 2021 | 09:25 AM
Birdsfocusst225
Birds st
Thank you so much I will have a look and try today and let you know.
thanks again
Old Nov 24, 2021 | 09:21 PM
Birdsfocusst225
Birds st
Default Boost issue
Hi all
After fitting new plugs, turbo actuator and knock sensor Im still having the same problem.
I'm really at a dead end with it please any ideas would be greatly appreciated
Old Nov 25, 2021 | 11:06 AM
cossie2's Avatar
cossie2
Check also position of the throttle plate maybe it is fluctuating with boost pressure
Old Nov 25, 2021 | 09:07 PM
Birdsfocusst225
Birds st
Default Boost issue
Ok I will do that but any other ideas for me to look into? I will take out and clean the map sensor to but I’m loosing patients with replacing parts for no reason
Thanks in advance
Old Dec 1, 2021 | 09:09 PM
Piezer's Avatar
Piezer
Air leak or blocked air pipe somewhere maybe
Old Dec 11, 2021 | 07:39 PM
stevieturbo's Avatar
stevieturbo
C**t
Thanks in advance
So why not find a competent mechanic who can actually diagnose the problem, instead of making matters worse firing the parts cannon ? Which in turn can often make it even more work for them to diagnose as they then have to trawl through and find everything that has been tampered with already, as well as sorting the underlying problem
A quick websearch brings these in Plymouth ?
Wasn't there a guy who used to work at MSD who also ended up down that area too ? ( or maybe that is him )
Philtingle
Jul 10, 2014 03:02 PM
Richyl398
Jan 2, 2014 12:50 PM
CBenno
Dec 18, 2012 05:07 PM
Stavros
24
Nov 26, 2004 03:23 PM
