12v to 5v
Anyone good with electronics. My dash requires 5v signals to operate the led warning lamps. Obviously the car is 12-14 volts when running. How can I drop that 12v signal down to 2/5 volts. I’m lead to believe there’s a way of doing it via diodes
Have you confirmed with AIM that they are not 12v tolerant ?
Would seem odd to have these features....and not suit normal wiring for such features. And a suitable resistor would drop it down.....for each circuit.
yeah I’ve seen a few. There’s just nothing out there that really shows how to physically wire in the road icons. It’s only the high beam indicators and factory oil warning I’m having an issue with. The ready is easy and links to my ecu
lol I mean resistors not diodes. I’ve ordered what’s in the wiring diagram they sent. There answer is the road icons are an after thought. Sensors largely use a 5v signal from an ecu
But if they say it needs resistors, I guess you need to do that shit.
They do, but often inputs can be tolerant of a higher voltage anyway even if they are not reading above 5v. In this instance they do not need to read, you're just triggering based on it being higher than 2v for example.
Something like this will do the job.
https://uk.rs-online.com/web/p/switc...ators/1933984/
There is probably some cheaper chinese junk on Ebay that would do the job, but it's not worth frying an expensive dash!
