Semi on sapphire Rs Cosworth
Old Sep 26, 2021 | 11:51 PM
MADMAXPTT's Avatar
MADMAXPTT
Default Semi on sapphire Rs Cosworth
Slicks on sapphire Rs Cosworth!
what semi slicks have you tried on a Sierra Cosworth?
am looking to buy a new set!
what is the best for it
Old Sep 27, 2021 | 09:23 AM
cossynut2's Avatar
cossynut2
10 Year Member
Are you talking about tyres for track day use? If so there are quite a few which are both road legal and suitable for track day. Toyo, Nanking, Kuhmo etc all have track day tyres. Prices vary quite a lot as well and remember you will need a matching spare in case you get a puncture.
Old Sep 29, 2021 | 10:29 PM
Ridgey's Avatar
Ridgey
I like the kumho v70.
Old Oct 21, 2021 | 07:32 PM
MADMAXPTT's Avatar
MADMAXPTT
I want it for road use, I used to have Cup 2 tires and behaved very well but now I want to fit something wider
Old Oct 22, 2021 | 08:45 AM
cossynut2's Avatar
cossynut2
10 Year Member
As i said in my earlier reply there are quite a few makes to choose from, depends on how much you want to spend.I currently have Federal 595RS 215/40/17 on my 2wd Saff. Remember not many will have the same wet road performance as a normal road tyre.
Old Oct 24, 2021 | 05:55 AM
MADMAXPTT's Avatar
MADMAXPTT
I was thinking about Toyos’s R888Rs, a tyre that has fast warmup, progressive grip and when you crossed its limit is also progressive.
there is a problem with standing water.
on light rain I believe that it will behave almost like Cup2s
a friend of mine has the 595RSR, it behaves good overall but needs a bit more time to warmup.
I have also seen Zestino and Nankang tyres (NS2R)
(all these tyres is sapphire Rs Cosworth (2wd)
Old Oct 24, 2021 | 10:22 AM
james kiely's Avatar
james kiely
ar1,s have a quick warmup.i have to say I had them on my resort track car and the car was stuck to the track with them
I'm gonna fit them to my escos when its done
Old Oct 25, 2021 | 08:18 AM
cossynut2's Avatar
cossynut2
10 Year Member
They are all good so it is a personal choice. As a matter of interest what power is your 2wd Saff? Mine is 450bhp and in the wet you have to be very careful with track day tyres that are designed mainly for dry weather. Do not think you can drive as hard as you can on road tyres that are designed to pump water out of the tyres!!
Old Oct 26, 2021 | 08:29 AM
MADMAXPTT's Avatar
MADMAXPTT
I have little more than 400hp with a T35, I used to drive it in the rain but with very soft touch on throttle to avoid any issue from my previous semis (Cup2)
i am afraid that if I do not have semi on my car there must be difficult to drive on dry because boost comes immediately (2,2 bar at 3500 rpm).
thats why I was thinking about R888R’s
Old Oct 26, 2021 | 05:16 PM
cossynut2's Avatar
cossynut2
10 Year Member
You will notice that with track day tyres you get a lot more grip off the line with less wheelspin. I can power slide mine in second gear on a dry road but there is no way I would do the same thing on a wet road!!!
nuttynil
Jun 22, 2008 11:00 PM
SS1
Jul 1, 2007 11:12 AM
All4it
16
Aug 22, 2005 11:52 AM
