P2187 fault code and hesitation/flat spot
Old Sep 8, 2021 | 10:06 AM
-JUT-'s Avatar
-JUT-
Default P2187 fault code and hesitation/flat spot
Hello all, I've recently bought an S-max 2.5 turbo but thought this would be the better forum to post in as I suspect there are more Focus ST drivers with the same engine on here than S-max drivers!
The car seems to bog down / have a flat spot at low revs and when pulling away from standstill but revs cleanly on WOT beyond about 3k RPM.
It keeps throwing this same P2187 code and a CEL every couple of days which can be cleared with a code reader but that does nothing to affect how the car drives and within a day or two the CEL and the fault code come back. P2187 fault code on my cheapo scanner is described as System Too Lean at Idle, Bank 1. I also scanned it with a proper Forscan tool but it came up with much the same info and no real suggestions as to the cause.
I tried cleaning the MAF which made no difference, and tried swapping it for a pattern replacement which made the problem much worse and made the car almost undriveable (guessing that the cheap MAF was giving inaccurate figures which were exacerbating the problem that exists elsewhere).
Any ideas what could cause this? The car seems to run fine at higher revs or when under full load, but the hesitation is getting on my wick when driving it in traffic etc. Sadly we can't go everywhere at full chat! If it could be an air leak somewhere, any suggestions on the most likely places to check? Car is standard apart from a stainless exhaust fitted by a previous owner so I don't have a boost gauge to see what level of boost it's running.
Thanks!
Old Sep 9, 2021 | 06:52 AM
oldford's Avatar
oldford
Any (small) leak in the inlet and/or exhaust manifold could cause this.
Can you read live data? What are the values of the both oxygen sensors and the Fuel trims at idle?
Old Sep 11, 2021 | 11:52 AM
-JUT-'s Avatar
-JUT-
Assume I can do this with Forscan but not sure how, anyone able to advise?
FWIW I found several splits and a clean break in the breather hose between the head and the oil filter housing, changed that yesterday, not sure if that might have been the cause?
Old Sep 11, 2021 | 04:05 PM
GVK.'s Avatar
GVK.
Fit a genuine BOSCH MAF
Old Sep 11, 2021 | 04:16 PM
GVK.'s Avatar
GVK.
Disconnect the MAF and drive it see if it runs better.
Old Sep 11, 2021 | 04:17 PM
GVK.'s Avatar
GVK.
Default air leak
that would do it , lol
Old Sep 13, 2021 | 01:45 PM
-JUT-'s Avatar
-JUT-
Sadly not. No CEL so far so I'm guessing that was causing the CEL but still got the flat spot. Car has a genuine Bosch MAF on it. Have tried cleaning it with contact cleaner but that didn't really make any difference.
Old Sep 13, 2021 | 11:04 PM
GVK.'s Avatar
GVK.
Tried driving it with maf disconnected?
Old Sep 14, 2021 | 08:16 AM
-JUT-'s Avatar
-JUT-
Yes, tried that now and seems smoother (better but still not 100% right is my gut feeling).
Guess I need to spring for a proper MAF not a cheap pattern one and go from there...
Old Sep 16, 2021 | 09:46 PM
GVK.'s Avatar
GVK.
yup, cheap mafs are crap
AngryAnt
Ford KUGA
Jan 18, 2022 05:48 AM
borinous
Ford Focus ST
Oct 29, 2012 01:39 PM
devilboy666
Mar 20, 2012 07:07 PM
rich123
Dec 13, 2011 08:42 PM
stevie-c
Ford Focus RS
Sep 30, 2009 09:58 PM
