Sapphire temperature gauge problem
Old Sep 6, 2021 | 06:47 PM
Ed1994's Avatar
Ed1994
Default Sapphire temperature gauge problem
Have a Sapphire temperature gauge problem , the sender is a brand new unit and iv tryed differnt clocks , my problem is that when I start the car cold my gauge started to go up instantly and when ya car gets warm it just goes to the red as if its over heating and car is not over heating , what else could it be anyone got a wiring diagram or anything thanks
Old Sep 6, 2021 | 08:34 PM
Mark V8's Avatar
Mark V8
There are different colours of sender units that are matched to the dash, you might have been supplied the wrong one for your car?
Old Sep 7, 2021 | 06:04 AM
Ed1994's Avatar
Ed1994
the one I got seams to have no colour on it and way to find out colour I need
Old Sep 7, 2021 | 02:08 PM
XR2's Avatar
XR2
Does it also go up when you turn the key without starting the engine?
Old Sep 7, 2021 | 02:16 PM
Ed1994's Avatar
Ed1994
no I think when ignition is on without running it stays down but need to double check
Old Sep 7, 2021 | 08:44 PM
Mark V8's Avatar
Mark V8
How helpful are your Ford dealers over in Ireland?
Might be worth giving them your vin and seeing if they are still available or know the colour code?
Old Sep 8, 2021 | 04:51 AM
XR2's Avatar
XR2
Probably not as Ford usually lists all colour options. The spare parts catalogue just says: Order the colour you have right now.
Old Sep 12, 2021 | 04:26 PM
cossynut2's Avatar
cossynut2
10 Year Member
You need one that has a black ring at the bottom of the threaded end which the connector goes on. Mine is a 2wd Sapphire Cosworth.
Ed1994
Jun 26, 2021 07:51 PM
Arisuse
Ford Fiesta
Jun 5, 2015 12:09 PM
slydawg65
Sep 10, 2010 03:47 PM
silky16v
Nov 19, 2008 12:12 PM
tomhs123
Jun 2, 2007 12:08 PM
