Ongoing altetnator overcharging issues.
Old Jul 25, 2021 | 07:59 PM
Angela123's Avatar
Angela123
Default Ongoing altetnator overcharging issues.
We have a 58 plate 1.6 Focus. 51,000 miles. Deisel.
Last year we had the ecu completely fried by a battery dying, at a cost of £1k.
This year we've had a new alternator because an error came up.
Two months later the car is still having power issues. Lights flickering when turn wheel, or when putting window up.
We've taken it back and the garage have found the alternator is over charging at 14.9 instead of 13.8 - 14.4.
When you google over charging alternator, it can lead to boiling of the acid in the battery, which in turn can lead to frying of the ecu, which has happened to us already.
What my question is, is this a common problem with Focus's ?
What wider issue could be causing the alternator to be overcharging, because both the battery and alternator are new.
We're at our wits end, and just want to get it sorted before the ecu is fried again.
Many Thanks
Old Jul 27, 2021 | 08:34 AM
oldford's Avatar
oldford
Ford does use a system called Smart Charge. With this system the charging voltage can be higher than normal and can rise (with a cold battery) to more than 15 volts.
The Alternator is controlled by the engine management system and fault's can be read from this system.
matt24680
Sep 5, 2013 04:53 PM
mobb-black
Nov 17, 2010 10:26 PM
craig todd
Apr 15, 2008 10:36 AM
mr_intex
Oct 12, 2007 05:40 AM
djmillsy
Dec 28, 2006 01:02 PM
