What cams
Old Apr 15, 2005 | 02:20 PM
Bakster's Avatar
Bakster
Default What cams
Hello. As you know I'm from Poland. So in my country I can't buy cams. So I will get them from burton power. And here is problem becouse I don't know what product I have to buy I want to get about 220-250 Hp in my car so what cams it have to be??
PIPERBP285T2
Kent CVH37
Kent CVH36
Kent CVH35
Kent CVH34
Old Apr 15, 2005 | 02:21 PM
rsmadandy's Avatar
rsmadandy
piper m8
Old Apr 15, 2005 | 08:02 PM
turbo.jon's Avatar
turbo.jon
Kent CVH35 no probs with mine
Old Apr 15, 2005 | 09:26 PM
glenis's Avatar
glenis
PIPER 285 T2
accept no imitations !
get that cam kit, forget anything else
it is the best cam avaliable for an RS TURBO
Old Apr 16, 2005 | 12:38 AM
CasperR's Avatar
CasperR
Originally Posted by glenis
PIPER 285 T2
Just make sure that your "tuner" knows how to dial in the cam, because ALL the tuners I have asked just set the pully to 0, or they say that "its a turbo car you just add boost"
Old Apr 16, 2005 | 08:12 AM
HybridBly's Avatar
HybridBly
I used to have the piper but found using high boost it worn very quickly, ive got the Kent cvh35 now and not had a prob for over 1 1/2yrs
Old Apr 16, 2005 | 11:09 AM
JesseT's Avatar
JesseT
I find that the CVH35 doesn't pull that well under 4000 rpm but then it likes to pull all the way to 8000rpm. I hear that the CVH34 is better in that aspect and produces power earlier. It's easy to get power with bad power band. Now I'm using a CVH efi cam slightly advanced. Amazingly it pulls really hard right from 2500 rpm.
So, when buying a cam, first look at your current spec, then decide what you want. The desired power level alone doesn't say much.
Old Apr 16, 2005 | 12:55 PM
radiant red's Avatar
radiant red
My car, still a 1600 made 230 bhp yesterday on the rollers using a 285t2.
Old Apr 18, 2005 | 06:06 AM
bradsescort's Avatar
bradsescort
what type of advance/retard do you guys run with how much boost and which camgrind?
Old Apr 18, 2005 | 04:35 PM
rs-nut-john's Avatar
rs-nut-john
a mixed bag on this subject, from what ive been told and read the CVH35 comes out on top of the picking list. And 2 be honest m8 i think untill u have had them all u will never know which 1 is best 4 u....
Old Apr 21, 2005 | 12:54 PM
Badman38's Avatar
Badman38
forget about piper or kent get yourself a newman cams last alot longer and if nyou give him a spec he can grind one for you only down side is setting up the soild lifters but i've done so many now that they are a piece of piss
i dont rate kent cams blanks the quality not there
Old Apr 21, 2005 | 01:14 PM
Philly's Avatar
Philly
Well I pulled 232bhp with a naturally aspirated cam!!
Haha! Was a bastard to set up though!!
Newman Cams do sound quite good though, chilled iron aint it?
Old Apr 21, 2005 | 05:26 PM
GrimmeRS2K's Avatar
GrimmeRS2K
gotta kent cvh 34 in mine, good early power band, had it a year, think its wearing badly though as i can hear it knocking now and again
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
