Help with Sierra rear Driveshaft CV Joint screw up
General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi
I disassembled the rear driveshaft & CV joints only to mix them up.
One of the bearings has a 4 stamped on it and the other one has a 7, see the picture
Does anyone know if this should be fitted on the diff side or the wheel side of the drive shaft?
Is it fitted on the same location on both driveshafts?
Thanks....
Brian
