GEM module?
Old May 24, 2021 | 06:16 PM
focus on ford's Avatar
focus on ford
Question GEM module?
Hi I would just like to ask the member do you need to match up the number on the GEM module or would they work in any focus if they are from a focus. I am having problem opening the car doors (CL) and been told to replace the GEM unit to solve the problem. So do I need to match them up or do they work in any car (ford focus 2002) sorry for been a pain all I seem to do is keep asking the member for some form of help, thanks for read and any advice you can give.
Old May 24, 2021 | 06:30 PM
STeve's Avatar
Super Moderator
gem modules can be changed no bother, ideally you need one with same numbers as they vary due to spec on various models then you simply pair the remote on your key to new gem unit
Old May 24, 2021 | 06:43 PM
focus on ford
Thanks Steve for your reply, So as long as the model no. match up. it would not matter what car it is from? thanks Paul.
Old May 26, 2021 | 06:44 AM
STeve's Avatar
Super Moderator
as long as ford numbers match it will work
Old Jun 14, 2021 | 08:13 PM
focus on ford
Hi Steve just want to say a BIG thank you for your help with my GEM issue. I have getting one and had it fitted. Everything is work fine, thanks for your help, take care and stay safe Paul.
Old Jun 14, 2021 | 08:24 PM
STeve's Avatar
Super Moderator
your welcome
Old Jun 15, 2021 | 03:24 PM
Rsmat's Avatar
Rsmat
Still top place for advice this ,
ford25
Apr 24, 2008 09:21 PM
ST EDDIE
Jun 10, 2006 09:26 PM
Dave Parker
Ford Mondeo Including ST
May 16, 2006 04:02 PM
