New Centre push hydraulic clutch just fitted.
Just got my 2wd Saff back from Julien Godfrey . They fitted a new centre push hydraulic clutch conversion plus some other work and they did a first class job. It was not straight forward but they overcame the problems and I am very pleased with the result. I can even get it into reverse now without the usual crunching and it has definitely made gear changing much smoother.There is no comparison to the side push conversion that I had done years back. They found a lot of problems which were at the point of becoming very serious so it was a good job I got it sorted now. Never used them before but I would have no hesitation in recommending them to others.
james kiely
Mar 21, 2017 09:45 PM
CliffRS4
12
Jul 4, 2006 08:26 AM
