Cossie 4x4 transmission oils
Old Apr 21, 2021 | 07:45 PM
gcfcos's Avatar
gcfcos
Default Cossie 4x4 transmission oils
I know this will have been discussed many times but can't find a search function on the app. Just about to change all fluids on my saph 4x4 cossie. I have mt75 oil for gearbox and atf dextron 3 for transfer box. What do the front and rear diffs take? 75/90 rings a bell from the past? Thanks
Old Apr 21, 2021 | 09:29 PM
GVK.'s Avatar
GVK.
Go here and add your reg gives you all the oils for your car - https://applications.castrol.com/oil...en_gb/c/search
Old Apr 21, 2021 | 09:39 PM
GVK.'s Avatar
GVK.
I got a 4x4 Cos reg off Google doesn't seem to be a standard oil listed for the diffs They list a load of them!
75w90 seems to be the one searching on here
https://shop.grahamgoode.com/ford-si...rt-74970-p.asp
Old Apr 22, 2021 | 07:51 AM
I'm sure I've used 75/90 my diffs. I even think it's in my gearbox too.
Old Apr 22, 2021 | 04:30 PM
gcfcos's Avatar
gcfcos
Found my old records, mt75 oil for gearbox, atf dextron 3 for transfer box and 75/90 for front and rear diffs
RWD_cossie_wil
29
May 22, 2008 10:16 PM
KSA-Cossie
Jan 10, 2007 01:55 PM
KSA-Cossie
13
Jan 7, 2007 03:01 PM
Richie.
May 29, 2006 12:58 PM
Mar 13, 2004 10:32 AM
