Tailgates
Old Apr 13, 2021 | 08:32 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Default Tailgates
Looking at a new tailgate but i want one to fit 88 spec spoiler and i believe 90 spec boot spoiler mountings are different from 88 spec is this true?
Would an early xr3i tailgate with the unpainted spoiler have the same mounts for the RS Turbo 88 spec spoilers?
Cheers.
Old Apr 14, 2021 | 01:54 PM
Thrush's Avatar
Thrush
Irritating c........
I had an 87 XR3i (with unpainted spoiler) and fitted a 90 spec unpainted spoiler and don't remember having to modify the mounts or drill new holes
Old Apr 30, 2021 | 08:09 AM
nathansRS's Avatar
nathansRS
c++
Both spoilers have 5 fixings
2 bolts and 1 nut at the tailgate lid end and 2 bolts at the other end on opposite sides of the glass
the 2 bolts and 1 nut at the tailgate lid are the same across all spoilers and all hatches, painted or unpainted, the 2 either side of the tailgate glass are different
88 tailgate with a 90 spoiler:
the 2 bolts and the nut at the boot lid fit ok, the 90 spoiler is longer so goes further up the tailgate either side of the glass.
this won't be a problem as the 90 spoiler will cover the 2 upper holes which are way off on the 90 spoiler, but you can bond the top part.
90 tailgate with an 88 spoiler:
the 2 bolts and single nut are fine again, but the 2 bolts either side of the tailgae glass are further up and so will acutally be exposed user the end of the 88 spoiler either side of the glass. you can see about 80% of the fixing collar, so you will need to address this.
in answer to your question an 88 tailgae and 88 spoiler (painted or unpainted makes no difference) fit perfectly.
cheers
Old Apr 30, 2021 | 09:16 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Thank you
Rs-Simon
Mar 24, 2008 11:33 AM
e900 ddv
13
Jan 18, 2007 09:17 PM
BIGEVILRTS
Mar 21, 2006 11:19 PM
-beefy-
Dec 23, 2005 08:16 PM
