Using correct slave cylinder with 0.625 master cylinder
Old Apr 10, 2021 | 10:33 AM
defendant's Avatar
defendant
Default Using correct slave cylinder with 0.625 master cylinder
I'm thinking of doing a hydraulic clutch conversion on a mk3 FRST, still CVH on a BC gear with a paddle clutch and heavy duty pressure plate. I will be using a master cylinder with a 0.625 bore, but what size should the bore be on the slave cylinder?
Thanks
BRAM
Feb 25, 2014 08:22 PM
nigel b
Apr 15, 2013 09:41 PM
