Bad starting
Old Apr 3, 2021 | 07:55 AM
Basco's Avatar
Basco
Default Bad starting
Hi all
can anyone help with this problem with my 3 door cossi
when cold car will only start with my foot half way down on accelerator once running its lumpy for about 30 45 seconds then clears runs and drives fine
when hot does the same thing
plugs are good
clearance in phase sensor and TDC sensor are correct
injectors were pro cleaned last year
only thing I haven’t changed is the fuel filter which is on order at mo
any thoughts would be much appreciated
Old Apr 6, 2021 | 10:25 AM
Zigu's Avatar
Zigu
10 Year Member
Hello,
Please check MAP.
A bad manifold absolute pressure (MAP) sensor can upset fuel delivery and ignition timing. Depending on your vehicle model, your engine might experience one or more of these performance problems:
  • Rich air-fuel ratio
  • Lean air-fuel ratio
  • Surging
  • Poor fuel economy
  • It won't start
  • Lack of engine power
  • Stalling
  • Detonation and misfire
col93saphcos
14
Apr 2, 2016 03:44 PM
ADT168
22
Feb 3, 2009 05:33 PM
XRT_si
Dec 2, 2008 06:04 PM
stevemex
14
Sep 26, 2008 12:56 PM
Diablo
May 29, 2004 04:07 PM
