PF09 TPS
Old Mar 23, 2021 | 07:30 PM
adduk's Avatar
adduk
Default PF09 TPS
Evening all
Whats the chance someone has a working PF09 TPS sensor they no longer need and willing to let go. I have the PF01 but it doesn't work with the MAXXECU due to it being open circuit causing issues.
If someone has one let me know please.
Cheers Adam
Old Mar 24, 2021 | 05:53 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
not familiar with that ecu or what engine you're using it on but consider the following:
if its a speed density setup (e.g. YB cosworth turbo) the throttle pot is used to tell the ecu the rate at which you open the throttle (not the specific position of it) so that it can enrich fuel correctly and also to allow the ecu to cut fuel at deceleration (closed throttle & higher revs)
for that reason you may be able to work around the switch problem of the pf01 by connecting a resistor from the wiper connection to ground so when the throttle is closed the ecu sees 0v. from memory the total resistance of the track is 500ohms so perhaps a 10k resister would be fine.
in the software you usually 'teach' the ecu the voltage at fully closed throttle and also at fully open although the specific voltages at those points are not critical and neither is the linearity which would suffer slightly with this approach.
easy to try if you cant find a fp09
Old Mar 26, 2021 | 03:22 PM
stevieturbo's Avatar
stevieturbo
C**t
Originally Posted by adduk
Evening all
Cheers Adam
If it only goes open circuit when "closed"....adjust the sensor round a little so it never goes to that position.
Old Mar 26, 2021 | 03:23 PM
stevieturbo
C**t
http://www.bigturbo.co.uk/main4.htm
Old Mar 30, 2021 | 09:37 PM
Rsmat's Avatar
Rsmat
Plenty of other TPS you can use im sure mate without the added Rs tax on a pf09 ..although I think my mate has 2 spare
timsrs
May 14, 2016 06:29 PM
Marc D
Apr 24, 2015 08:31 PM
Mungus
May 7, 2012 09:07 PM
wing
Ford Escort RS Cosworth
Jan 17, 2008 09:05 AM
