235/45/17 rear 215/45/17 front 2wd cosworth rubbing issues?
Old Mar 14, 2021 | 10:50 AM
Saff2wd's Avatar
Saff2wd
Default 235/45/17 rear 215/45/17 front 2wd cosworth rubbing issues?
I’ve just brought some compomotive mo5s 7.5x17 ET37 they are fitted with 235/45/17 on the rears and 215/45/17 on the front tyres are toyo r888s which are a little wider then Normal tyres I’ve had a look on the forum and found a red spah that was running 8x17 235/45/17 with et40 but had a 6 degree beam just wondering if I’m likely to have any issues with rubbing? Also I’m on avo adjustable coilovers. Thanks
Old Mar 14, 2021 | 04:37 PM
Mark V8's Avatar
Mark V8
I've got 8 x 17 on the back with 235/40/17 and had to beat my wheel arch lip flat to get them to clear.
45 sidewall will make them quite tall compared to a 40
Old Mar 14, 2021 | 05:14 PM
Saff2wd's Avatar
Saff2wd
What offest are yours buddy? my main concern was rubbing on the inside of the car (rear shock) I’m not to worried about height as I’ve seen saphs with 19” wheels before and loads of people have 18” wheels
Old Mar 14, 2021 | 05:50 PM
Mark V8's Avatar
Mark V8
ET40, but I've got two piece rear discs and the bells are around 8mm thick from memory - so probably nearer to a true ET35 .
I've not driven the car yet and it does have a very roughly adjusted 6 degree beam
On the bump stops after bashing the arches
Old Mar 14, 2021 | 09:33 PM
Saff2wd's Avatar
Saff2wd
That is very close may look into getting my arches rolled 235 45 17 seems to be very close overall to 235 35 18 so hopefully no issues
627mm v 643mm
Old Mar 14, 2021 | 10:35 PM
Mark V8's Avatar
Mark V8
The front might be more of an issue with the taller tyres and the bottom spring platform depending on where you want the ride height to be.
7 1/2 x 17 ET35 with 215/40/17 Federal 595 RSR in pic.
Old Mar 14, 2021 | 11:24 PM
Saff2wd's Avatar
Saff2wd
To be honest I didn’t even give the front a thought luckily I’ve got adjustable coilovers I need to run my engine in for next 500 miles or so may have to change tyres after that if there are any issues I think 215 45 17 are only 22mm bigger than the 215 40 17 so 11mm higher hopefuly I can adjust the suspension to suit the r888s that are on the comps I brought as they have loads of life in the would be a shame to have to change them Ł I’ll post up my findings
Old Mar 18, 2021 | 08:03 PM
Ridgey's Avatar
Ridgey
45 profile is just too big on 17s.
40 is where they should be and that is still bigger than std rollin* radius.
I run 235/40 17 all round but arch work is definitely needed, and the reason people stay with skinny fronts (205 or 215) is because of arch clearance on the front.
Old Mar 18, 2021 | 09:00 PM
Saff2wd's Avatar
Saff2wd
I know it’s slightly too big and the front are 215 I’ve seen a couple of picture of Sierra track cars that look like they are running a 45 profile with 17” wheels but I don’t know what arch work they have had done and the trouble is I want a tire like r888 or ns2r and they only seem to do them in a 205 40 17 and my rims are 7.5j so 205 is abit stretched which i don’t like but I did see a
sierra on here with 19” tsw pace wheels I think I’m just going to have to fit them and see what’s the biggest thing is when I do put my foot down being a 2wd the rear is really going to kick down on the wheels
Old Mar 18, 2021 | 09:07 PM
Saff2wd's Avatar
Saff2wd
These are look like a 45 profile?
Old Mar 18, 2021 | 09:38 PM
Mark V8's Avatar
Mark V8
I've got Federal 595 RSR track day tyres with 215/40/17 on the front
Old Mar 19, 2021 | 09:20 PM
Saff2wd's Avatar
Saff2wd
They fit!
might be some rubbing issues but doesn’t look as bad as I thought it would will report back after I’ve test driven it in a couple of weeks
Old Mar 20, 2021 | 04:22 PM
cossynut2's Avatar
cossynut2
10 Year Member
I think you will be ok as your Saff is not to low. Mine is lowered by 35mm and has 17x7.5 alloys with 215/40/17 Federal RSR tyres and without having rolled arches they would rub.
Old Mar 21, 2021 | 03:41 PM
Saff2wd's Avatar
Saff2wd
I hope so worst case senario I will change the rears to 215 45 17 I want to keep the ride as comfortable as possible without compramising too much grip
tosh
Dec 15, 2009 03:54 PM
chrisa3
Oct 28, 2009 08:30 AM
Fiecos Dan
Alloy wheels and ICE for sale
Jul 12, 2005 06:24 PM
RS500/364
May 12, 2004 05:36 PM
