YB Long Stud and Head Bolt Torque Settings
Old Mar 2, 2021 | 12:48 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Default YB Long Stud and Head Bolt Torque Settings
Hi guys,
I'm looking to confirm the torque settings for a block / head with 6 long studs and 4 standard stretch bolts across the ends. I've seen two recommended settings as follows:
1. 30lb, then 60lb, then 90lb on all 10 studs / bolts.
2. Do 30lbs, 60lbs, then 90lbs on the long studs. For the four stretch bolts, torque up to 25nm (18lb), 45nm (33lb) and then 180 degrees. This is the recommended settings from Ford for the stretch bolts.
Option 1 seems better to me as all will be torqued to the same setting. However, I'm mindful that the torque settings for the stretch bolts in option 1 seem considerably higher than what Ford recommend for the stretch bolts. Is this a concern from point of view of potential over torquing causing bolt failure?
Cheers,
Rich
Old Mar 7, 2021 | 06:16 AM
hakils's Avatar
hakils
Here are the guidelines from ARP courtesy of John Mummert. You may discover a portion of the data fascinating: Head stud and head jolt units are utilized to improve bracing of the head to the block, improving the clasping power diminishes the frequency of blown head gaskets. Early Y's were gathered with normal quality head jolts. These were updated late underway to Review 8 clasp (?????). This decreased the number of blown head gaskets however there is still an opportunity to get better. Our head screw and stud unit uses an ARP clasp which is a tremendous improvement over the creation of Y latches. These are 8740 amalgams with 190,000 psi elasticity. Either unit is an immediate supplanting without any mods vital. Early Y-blocks required longer darts at the finishes of the upper line of jolts because of the recessed strings at the square dowels. In 1960 and later heads the 5 upper head jolts are generally a similar length (I didn't realize that!). 192.168.100.1 192.168.1.1
Old Mar 7, 2021 | 02:02 PM
Ridgey's Avatar
Ridgey
If using std bolts they should be torqued in the std recommended way for that stretch bolt.
Old Mar 7, 2021 | 02:48 PM
pectelboy's Avatar
pectelboy
30 60 90 for long studs
ital_cossie
16
Jul 13, 2010 12:32 PM
smerth54
Mar 14, 2009 11:49 AM
dazrs
Sep 24, 2008 06:31 PM
ASHCOSSIE
Jan 28, 2007 01:09 PM
DOO
Aug 23, 2005 05:14 PM
