Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
window removal
Old Feb 15, 2021 | 06:56 PM
sstump's Avatar
sstump
Default window removal
Hi,
can anyone tell me how to remove the drivers door window motor, I want to see if I can get working?, keeps staying down so I hit it with a hammer to get it back trouble is does not work all the time
ford focus cc3 09 petrol
regards
Old Feb 15, 2021 | 07:26 PM
Thrush's Avatar
Thrush
Irritating c........
Glass is held onto the mech via clamps - there's two holes in the door skin, with rubber covers that you pull out, where you can access the clamps. Each has a 10mm bolt to tighten/loosen - don't undo it the whole way or you'll drop it in the door. Only needs 3 or so turns. Loosen both, hold the glass, lower the mech. Tilt front edge of glass forwards and lift out the door. That's as far as my expertise goes: I probably have replaced a Focus mech at some point in the last 15 years but I couldn't tell you how to remove it blindly. Probably riveted in (most are, but might be held in with bolts. If the motor is on the outside of the door skin, you'll need to remove that first (usually three or four torx screws) and unbolt/drill out mech rivets and rotate mech and until you can get it out the door (probably through an access panel rather than the top. Of course, if the motor is on the outside, you won't need to remove the actual mech (assuming the motor is at fault because you hit it - I'd start by replacing that, and inspecting the teeth on the mech to check none are chipped or missing)
Old Feb 15, 2021 | 08:27 PM
sstump's Avatar
sstump
Hi Thrush many thanks for the quick reply.
Just checking does this relate to the cc3 09 car or are they ball the same?
Old Feb 17, 2021 | 01:44 AM
Thrush's Avatar
Thrush
Fault on my part - I didn't spot to CC3 part, and focussed (no pun intended) on the year - I've never done a window on a convertible Focus, so I couldn't say with any certainty
Old Feb 17, 2021 | 12:58 PM
sstump's Avatar
sstump
Hi,Thrush,
many thanks for your reply, much appreciated.
brett_
Jan 20, 2011 06:23 PM
kidsRS
Jun 5, 2010 07:14 AM
BigJim19
11
Jun 30, 2009 11:02 PM
rs nutta
Apr 7, 2006 05:16 PM
JeffJ
Apr 28, 2005 09:31 AM
