anyone tryied athena mls with cooper rings gasket? gaskets
Old Jan 8, 2021 | 10:42 AM
sierrafun's Avatar
sierrafun
Default anyone tryied athena mls with cooper rings gasket? gaskets
that is mls gasket 2mm with cooper rings need no machine for the block ..are they good for high boost ?anyone tyied ?
Old Jan 8, 2021 | 04:17 PM
cossie2's Avatar
cossie2
...i have one in my escos..the rings are stainless steel..so far ok..before i had similar Italian Nava sport cylinder head gasket but couldnt get one so i have ordered this one..much more expensive than Nava..
Old Jan 8, 2021 | 04:33 PM
sierrafun's Avatar
sierrafun
is true that not need to machine the block ?
Old Jan 9, 2021 | 05:55 PM
cossie2's Avatar
cossie2
Yes..it is..as the rings with their edge bite in head..As above use to have Nava gasket but couldt get it so i am using this now..
Old Jan 10, 2021 | 09:41 AM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
'proper ' head gaskets are Ł130 on eBay
Old Jan 11, 2021 | 07:56 AM
sierrafun's Avatar
sierrafun
thanks mate very helpful
Old Jan 11, 2021 | 07:57 AM
sierrafun's Avatar
sierrafun
i bought cometic 2mm mls and failed in 300 miles . look for a betetr gasket ..spec are t34 greys 1.9 bar boost
Old Jan 11, 2021 | 08:03 AM
sierrafun's Avatar
sierrafun
i need fit 2mm gasket only for a very skim head ..so i need something strong .ebay has cometic gasket 2mm .poor quality i think
Old Jan 11, 2021 | 08:56 AM
20/20 vision
https://www.ebay.co.uk/itm/COSWORTH-...MAAOSwe-heZpHW
Old Jan 11, 2021 | 09:02 AM
sierrafun's Avatar
sierrafun
that is a 1.4 mm i look for 2.mm
Old Jan 11, 2021 | 09:17 AM
20/20 vision
why?
if you're fitting a metal gasket you require a perfectly flat block and that means you need the engine in bits to machine it.
when it's in bits machine the pistons with pockets if you're concerned about valve/piston contact, face a little of the top of the piston if you're worried about piston / head contact or compression ratio.
Old Jan 13, 2021 | 10:28 AM
cossynut2's Avatar
cossynut2
10 Year Member
I have a 200 block, machined to take wire rings at the top, group A spec head, group A head gasket, pocketed low comp pistons, run 2 bar boost at 450 bhp and have done nearly 60k miles with no issues. Old school way but it still works.
Old Jan 14, 2021 | 04:12 PM
sierrafun's Avatar
sierrafun
i hear from owners the group a gasket is fine.. the cometic gasket dont last many miles ...also i hear from mechanics generaly when a gasket is thick like 2mm and above is risk on big power ..they failed easy ..
bigdel
11
Oct 7, 2016 06:54 PM
escort1989uk
May 5, 2011 08:05 PM
marcus264
Aug 19, 2007 11:03 AM
rob w
May 20, 2006 10:09 AM
cosworthbg
Aug 24, 2004 11:18 AM
