4X4 Uprights, CV axel ABS vs non-ABS
Old Jan 2, 2021 | 12:58 PM
Uroford's Avatar
Uroford
Default 4X4 Uprights, CV axel ABS vs non-ABS
It is my understanding that both abs and non uprights are the same but abs are machined for the sensor? My question is there a difference between cv drive axels with the sensor ring and not? Are the stubs and splines the same length? I have a problem with loose bearings on an abs upright where the nut seems to be holding with only 4-5 threads and wondering if I've got a mix of incompatible parts?
Old Jan 2, 2021 | 03:29 PM
Cossy Mike's Avatar
Cossy Mike
They are listing different part numbers so something differs with abs and none abs. My understanding was Cosworth have there own stubs shared with granada
Old Jan 2, 2021 | 04:40 PM
Marc sierra's Avatar
Marc sierra
I would look at the back to see if the drive shaft is pulled in completely. Not sure on the ABS vs. non-ABS, as almost all 4x4’s had ABS. Is yours an early XR4x4?
Old Jan 2, 2021 | 05:38 PM
Uroford's Avatar
Uroford
I have abs uprights, just wondering if some cv (driveshaft) stub axles were shorter and some longer, abs vs non?
Old Jan 4, 2021 | 12:37 PM
Uroford's Avatar
Uroford
I have found that XR4X4, Saph, Scorpio and Escort Cossie all have different part numbers for the front outer CV. What is different on Escort is there is no listing for this washer
And Escort
Could this result in a shorter stub if designed with no "retaining washer" in the stack up?
Old Jan 23, 2021 | 12:24 PM
Uroford's Avatar
Uroford
Is this the washer 17 that I referenced above?
does this need to be in place on a 4x4 sapphire between the cv and hub bearing?
Old Jan 24, 2021 | 02:29 PM
Marc sierra
It is not there on mine.
Spiky
11
Apr 9, 2011 08:32 PM
col cos1
11
Jul 26, 2007 07:34 PM
May 29, 2007 06:45 AM
A.J.
Apr 11, 2006 02:08 PM
