MK3 Fiesta with 1.6 CHV. Needs engine work, rebuild?
Old Dec 26, 2020 | 11:39 PM
Fiestamk31.6cvh's Avatar
Fiestamk31.6cvh
Default MK3 Fiesta with 1.6 CHV. Needs engine work, rebuild?
First can you tell exactly what engine this car has? I know it is a 1.6, were there variations of the 1.6?
Car is smoking, not sure if it is HG/Piston or rockers. I have attached a picture of the smoke, the smoke is mostly there on idle.
The hose going from the head to the crankcase on the right of the engine bay is rock hard.
It has a webber carb, does the card look familar to anyone? I may try and rebuild it.
The car was a 1.1,
exhaust manifold - Part number - 89SF9430EB -
Gearbox - 87TT-7F096-BB
Engine Block - 87TT-7F096-BB
Engine head - 1.6 stamped.
Carb Webber.
distributer - pgfudx4 - mk3 escort
Old Dec 27, 2020 | 06:22 AM
paulee's Avatar
paulee
Haynes manual mate well worth the pennies. Xr2 has gave u a good list to check/do. Also is that oil on your exhaust tip? High idle could also be advance and retard on the distributor if its been put back on wrong.
Fiestamk31.6cvh
24
Feb 7, 2021 01:45 PM
Fiestamk31.6cvh
Dec 25, 2020 05:17 PM
Fiestamk31.6cvh
Ford Fiesta
Dec 24, 2020 07:14 PM
