Mk7 Fiesta Warm Start Problem
Old Dec 19, 2020 | 12:35 AM
Kev's Avatar
Kev
Default Mk7 Fiesta Warm Start Problem
Hi all. Looking for some help please.
Mk7 1.25 fiesta with high miles! Have a warm start problem. From cold, no problems at all, starts every time. But once the engine is warm, it sounds as if the solenoid isn't throwing the gear out on the starter. But i've not had this problem and i'm only assuming that's what the noise is. I've attached a video of the noise it is making. The video also shows that it will eventually crank the engine over after a few tries.
Thanks in advance for any help.
https://imgur.com/a/Zs0LsSe
Old Mar 30, 2024 | 02:52 PM
elrenrob's Avatar
elrenrob
Default Same issue
Hi Kev,
did you ever get to the bottom of this? I have exactly the same problem on the 2009 1.4 Zetec. On cold start, starts perfectly every time. As soon as the car gets warm, any restart “wheezes” when cranking the ignition
Adrianghill
Mar 31, 2024 01:25 AM
Steve T
Fiesta's Other !
Jan 21, 2015 11:04 AM
Andrew Pisani
Jun 18, 2013 06:04 PM
thegrimreaper
May 20, 2006 11:11 PM
