Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Big problem with my Ford focus cmax 1.6 TDCI T1DA
Old Dec 8, 2020 | 07:48 AM
flyb87's Avatar
flyb87
Default Big problem with my Ford focus cmax 1.6 TDCI T1DA
Hi everybody,
i have a Big problem with my Ford focus cmax and i Hope to find the solution with you.
The problem appeared during a long drive. Passage of the car in degraded mode
Diagnosic of the garage owner: 4 HS injectors + EGR valve except that he did not have the parts to change the injectors.
I had to go home (900km I was on vacation).
the maximum speed of the car was 90km / h
it is at 600Kms that the car got into fault with the engine, immediate overhaul with a bride at 2500- 3000 rpm max
I ended up going home.
I changed the 4 injectors and following a passage of forscan, I noticed a code error: accumulation of soot.
I reinitiated the values ​​taken on by the DPF.
The error code is gone but the engine is still in degraded mode.
So I cannot learn injectors.
I removed the catalyseur DPF . It was hard. The connector between the dpf and the exhaust was welded by the rust !
I cut the screw with a dremel .
I wash the dpf just with water but i don't see dirty water .
The water who exit is clean like potable water. ( Just a little dirty water )
I went up the dpf and i dont have the dtc accumulation of soot anymore but now i have a p244d température is too High on the catalyst but After a lot of erase the dtc, i dont have this dtc anymore.
​​So i tried to go go the road with my car but After the 3rd, i have a dtc p2599
​​Turbocharger charge air pressure control position sensor A, performance problem - high signal....
it is possible that the problem is juste a air admission ?
Sorry for this Big texte but you are my only Hope.
Thanks
Bruno
flyb87
Ford Focus Diesel
Dec 7, 2020 10:43 PM
Andi Armstrong
Ford Focus (All Models)
Jul 31, 2018 10:07 PM
mickmusson
Ford Focus Diesel
Aug 23, 2014 07:43 PM
shanel
Ford Focus Diesel
Apr 1, 2012 08:50 PM
