help rs turbo s2 cossy managment
Old Nov 10, 2020 | 07:11 PM
tommyrs's Avatar
tommyrs
Default help rs turbo s2 cossy managment
hello hope someone help me i am lost
my s2 was fitted with cossy mangement but wont idle good when cold and afr is all over the place when it idle cold revs drop away and afr goes to max on gauge
tryed etrrything i can think of tested all temp sensors to me all are ok but changed them to be sure as dont cost much
also fuel pressure is 3.5 bar vac pipe of and drops to 3 on so that is ok
any one here got any idea what could be causeing this
thanks for any help
Old Nov 12, 2020 | 01:22 PM
martysmartie's Avatar
martysmartie
What is the CO?
Martin
Old Nov 12, 2020 | 01:55 PM
tommyrs's Avatar
tommyrs
when it went throw the mot it failed was 6% turned it down to 3.5 to get it throw but back up as it ran worse and was getting very warm
strangest also theres a sligt miss fire at low revs
Old Nov 12, 2020 | 02:09 PM
tommyrs's Avatar
tommyrs
could it be a problem with the camshft ??
Old Nov 13, 2020 | 12:40 PM
martysmartie
Was this setup/running correctly, or have you just had the conversion done?
Who mapped it?
Martin
Old Nov 13, 2020 | 12:47 PM
tommyrs's Avatar
tommyrs
it was done by jano at oddkidd creations
i bought the car like this but was running fine when i got it then it started to idle wrong and it just got worse
Old Nov 13, 2020 | 02:32 PM
martysmartie
It's worth checking the MAP reference hose has not split, is it only a problem when cold though?
Martin
Old Nov 13, 2020 | 02:53 PM
tommyrs's Avatar
tommyrs
i replaced all vac pipes there is no leaks and yes only cold once it warms up its fine
its got me beat cant seem to find the problem 😖
chrisRS357
Jul 29, 2010 08:18 AM
dale rs1989
Sep 7, 2009 08:09 AM
dale rs1989
Apr 18, 2009 08:38 PM
robbob
Mar 25, 2006 01:21 PM
Hrsturbo
Jan 27, 2006 12:36 AM
