Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
n/a cosworth engine + 4speed quaifebox...UPDATED..
Old Nov 6, 2003 | 06:32 PM
GaryEvo's Avatar
GaryEvo
Default n/a cosworth engine + 4speed quaifebox...UPDATED..
2.0ltr normally aspirated Cosworth engine
Head fully gas flowed and machined by Niel Roper Race engines,
Solid lifters L1 & BD3 cams fitted with adjustable verniers
Matched inlet manifold fitted with twin DCO48SP carburettors alloy trumpets,
Maggard spherical jointed twin throttle linkage, K&N Challenger air filters.
Cossie Block crank & rods fitted with normally aspirated Cosworth
competition pistons all engine parts & clutch were balanced
Titan Dry sump system, including pipes remote oil filter , dry sump tank and
oil cooler.
Steel lightweight flywheel fitted with AP twin plate ceremetalic competition
clutch
Exhaust manifold big bore tubular manifold
Ignition, Luminition constant energy system with rev limiter distributor is
Holby competition unit,
Starter motor is the compact short pre engaged type.
Alloy bell housing with left or right starter motor position at present it
is fitted on the nearside
G/box is a Quaife professional 4 speed ratios 1st 2:39 2nd 1:69, 3rd 1:34
4th 1:1 with close ratio jointed gear lever.
Engine unused since rebuild. We have sold the car and the power plant needs
a new host it would fit nicely into an Escort 1,2 it came out of our
Genesis RWD escort offers around £3500.00
Old Nov 24, 2003 | 08:33 AM
You have mail
Old Dec 3, 2003 | 12:32 PM
BigDave's Avatar
BigDave
Did this set up sell??
Old Dec 4, 2003 | 08:19 AM
Yes it did
Old Dec 4, 2003 | 03:38 PM
BigDave's Avatar
BigDave
DOH!! Would have been lovely in a Mk1!!
Old Jan 15, 2004 | 12:24 AM
whats the bhp and torque figures on this engine?
Old Jan 15, 2004 | 01:18 PM
BigDave's Avatar
BigDave
I was going to sell my NA lump but fancy it to be worth more than this ammount alone. Some one got a real baragin there!!
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
