Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Timing belt cover
Old Oct 29, 2020 | 11:37 AM
R. Suppards's Avatar
R. Suppards
Default Timing belt cover
I've just bought a Sierra Sapphire Cosworth and want to check the cambelt, it might sound a bit daft but how many bolts / screws hold the cover on? I can see 2 on the top and 1 on the front but are there anymore hidden as I still can't get it to move?
I don't want to force it and damage it,
Thanks
R. Suppards
Old Oct 29, 2020 | 02:26 PM
cossie2's Avatar
cossie2
...if it is the oe one there should be some on the bottom part i believe..if no than only those which you mentioned..
Old Oct 29, 2020 | 02:30 PM
bigdel's Avatar
bigdel
There’s a little 10mm bolt right down the bottom by the crank pulley, two on the top, one in the middle just below the cam pulleys and the shouldered bolt on the water pump (just pushes into a rubber grommet)
savvy
Jun 27, 2013 09:01 PM
fordrs2005
Aug 17, 2009 05:55 PM
fordrs2005
Mar 20, 2008 09:37 PM
AJC
Oct 24, 2004 05:17 PM
