Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Part number for intercooler hose please (split!)
Old Oct 2, 2020 | 06:39 PM
Antec's Avatar
Antec
Default Part number for intercooler hose please (split!)
Hey all
So this week I've been fighting with the infamous P0299 low boost error code and finally today i have found the culprit. There is a split on the under side bend on the intercooler cooler hose (circled in the pic)
Some advice, you need someone in the car holding the revs up so you can have a feel around the pipes to find any leaks. I should of done this on day 1. Instead was just having the engine on idle.
Car is a Ford focus 1.6 tdci 110bhp 2010 Estate with dpf.
Just wanted to double check, is this the right hose? Car has done 144k, not really bothered about getting a fancy silicone one.
https://www.ebay.co.uk/itm/322473733605
In the last week I've changed the oil, oil filter, air filter, maf sensor, pressure boost actuator and the turbo inlet hose from the air filter.
​​Thanks
Alan Morris
Ford Fiesta
Sep 5, 2020 07:25 PM
DA VE
Nov 29, 2014 10:30 PM
daviddunlop83
Mar 29, 2008 05:48 PM
