Fresh build LHD Ford Sierra Cosworth 4x4 replica for sale:
200 block green top engine(new seals, gaskets, oil pan fully cleaned, new cam belt, 36-1 crank wheel etc)
stock gearbox (viscous coupling has no leaks, chain is not stretched, fresh fluids)
new 4 paddle clutch, machined flywheel and uprated clutch cover
DTA S60 ecu, Siemens 630cc injectors, Garrett T34 .48, 360° bearing, new actuator new weber fpr,
RS500 cooler, new radiator with dual slim fans
Thick insert front Bilstein coilovers, recently revised
new GAZ coilovers at rear
poly bushed around, poly engine and gearbox mounts
new grooved discs, new OMP and EBC pads
all calipers rebuilt, painted, braided fuel lines
power steering rack is rebuilt
new plate type LSD at rear, 3.92 gears both front and rear
new front driveshafts, new rear CV joints, new wheel bearings
16x7 Sparco Cromodora wheels, Pirelli slicks
Hubs are redrilled to 5x100
Policarbonate side windows
Sparco bucket seat, RHS 3" harness
20l fuel cell
The chassis was originally a 1.8TD in good condition, only minor body work had to be carried out. Critical, weak areas were seam welded, strenghtened. Chassis number present but no paperwork comes with it.
Car starts and idles nicely, needs proper rolling road tune.
Located in Hungary. Delivery to the UK available.
Feel free to call for further info +36 30 237 0833
