PATS code 16 and DTC U2150. Engine Malfunction. Wont start.
Old Sep 26, 2020 | 07:07 AM
richardindorset's Avatar
richardindorset
Default PATS code 16 and DTC U2150. Engine Malfunction. Wont start.
I have a 2009 1.6 TDCI that won't start.
It also won't connect to Forscan, which is odd, so must be a clue as to whats going on.
The immobiliser LED is giving me 1 and 6.
I think the PATS code of 1:6 and DTC code of U2510 (comms between PATS and PCM) means there is a fault in the canbus wiring.
I'm going to check for dry joints / cracked joints on the instrument cluster but this is a hard fault and not intermittent.
Also going to check correct resitance across Canbus on at the OBDII port.
No blown fuses.
I got the codes out via the built in dashboard display.
Anything else worth checking?
Old Sep 26, 2020 | 10:37 AM
richardindorset
Canbus scopes out ok at OBDII port. 60ohms.
Resoldered all the pins in the instrument cluster. Some defo had cracks around them, but still no change.
PATS 1:6 and Engine/Transmission malfunction.
Forscan wont connect.
What to try next?
Old Sep 27, 2020 | 10:01 PM
richardindorset
Also checked power, ground and canbus at PCM. Still no dice.
Old Oct 2, 2020 | 08:30 PM
richardindorset
PCM is toast. Sending it off to ECU testing.
liamthecoder
Ford Focus Range
Sep 28, 2014 06:03 PM
rich123
Dec 13, 2011 08:42 PM
ccharlie
Ford Focus RS
Jan 5, 2011 02:49 PM
kingcol
Ford Focus RS
Dec 30, 2010 10:39 PM
stevie-c
Ford Focus RS
Sep 30, 2009 09:58 PM
