How to enable dvd watching function in moving car....?
Old Sep 10, 2020 | 08:23 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default How to enable dvd watching function in moving car....?
Just found out today I can play dvds in my car stereo on the screen on my dash.... Obviously it fades out when moving so the driver isn't distracted.....
Is it possible to disable that fade out function so my kids can watch while I drive?
Old Sep 11, 2020 | 02:02 AM
visa_broke's Avatar
visa_broke
10 Year Member
depends how it is connected, it used to be a wire connected to the handbrake switch. Maybe its something similar but knowing Mercedes its probably coded in some how.
Old Sep 11, 2020 | 08:02 AM
fuzzy's Avatar
fuzzy
Yes.... It'll most likely be a nerd with a laptop required rather than a mechanic with a screwdriver
Old Sep 11, 2020 | 08:27 AM
nick46's Avatar
nick46
VR46 The G.O.A.T
If its anything like BMW it can simply be coded.
Old Sep 11, 2020 | 02:31 PM
scoooby slayer's Avatar
scoooby slayer
My audi and Merc both play a dvd and it makes no difference if driving or not ?
maybe there's a setting in the menus mate
Old Sep 11, 2020 | 05:00 PM
fuzzy's Avatar
fuzzy
Specialist I use tells me it can't be done but searching on the Internet suggests it can....
Old Sep 17, 2020 | 10:29 AM
Caddyshack's Avatar
Caddyshack
My AMG E55 was obviously an older model but it was simply a multiple button press to enable it, you had to do a sequence of presses.
I expect yours will be a can bus signal off the speed / movement sensor or a park switch?...sounds like one for an AMG merc forum.
My Rangie has a prismatic screen so the wife can watch a DVD from her seat and I can look at the sat nav without each other seeing what the other sees. Clever stuff!
Old Sep 17, 2020 | 01:22 PM
fuzzy's Avatar
fuzzy
I seen that in a range rover before.... Playing 2 different things on the same screen at the same time.... Its witchcraft ​​​​​​
Mine is to old for that new fangled stuff.... 2008 so probably about the same era as your E55?
puddy
Alloy wheels and ICE for sale
Aug 23, 2010 10:36 PM
dojj
May 18, 2008 12:22 AM
K3V HA
18
May 10, 2005 10:38 AM
Sep 16, 2004 04:55 PM
