Battery disconnect 4x4 Saph Cos
Lately I am hardly using the car and often when I do go to use it, the battery is flat. Wondered about fitting some sort of disconnect switch, but if you know the standard set up on a 4x4 sierra Cosworth this does not look easy. Firstly it uses the flat post battery and secondly it has a plate with multiple wires attached. What if anything are others doing. I could just disconnect the battery completely but a bit more of a fiddle before and after using the car.
Also while reading this - I notice very little traffic on this forum these days. Where is all the conversation happening for Sierra/Sapphire/RS500 Cosworth these days. It it on facebook somewhere.
Thanks
David
Thanks
David
Hi David, i use a battery conditioner, and to date its been faultless.
After having the same issues when going to start mine i looked about, i did have one that used a push fit connection from a fly lead but became awkward to use just have a simple croc clips now and its seconds to disconnect.
Yeah I'm fully powered in the garage, dropped in a new armour cable and cu when the old concrete floor came out.
Fully re wired and new lighting went in. I wouldn't have been happy before with heater and dehumidifier running and the battery conditioner without it all replaced.
Yes, made the trip to Whilton mill and it was a damp start but ended up dry and to honest it was a cracking turnout.
Hope your keeping well and we get to catch up next year face to face.
Hows that effect the alarm/immobiliser??
Thats my reason for not disconnecting the leads.....mine original had a kill switch but once that was off the doors wouldn't lock and the alarms were useless.
Thanks for all the replies guys. As said - A trickle charger is probably the best option but I am also temporarily without a garage at the moment so not as easy. As can be seen from Mad_Mat's solution, there are a heap of other wires connected directly to the battery that need to be disconnected if that's the option chosen. Mat - is that a single item that can be purchased or is it made up of a couple of units. Thanks again. David
I have something similar to Mat, its a great solution, car is isolated and completely reduces the risk of fire ! Seen too many guys lose cars and garages due to trickle chargers etc being left plugged in constantly.
