Bit of launch control
Old Aug 20, 2020 | 04:28 PM
scoooby slayer's Avatar
scoooby slayer
Default Bit of launch control
Thought you lads would like this tried out abit of launch control today for the first time
Old Aug 20, 2020 | 04:57 PM
turnover's Avatar
turnover
So it’s around 3.2 to 3.3 to 60 then,that’s not bad for a big barge
Old Aug 20, 2020 | 05:37 PM
markk's Avatar
markk
Fast that
Sounds sweet on the change. Twin clutches are the way to go for sure.
scoooby slayer
The 3 runs on screen were 3.1, 3.2 and 3.4 but I think the box must be set up for 12" rollout for 1/4 mile
Alot better than 4.7 that's for sure pal 😁👍
Just checked it has 12" rollout enabled so set up for 1/4 mile rather than from dead stop
Best run
Old Aug 20, 2020 | 05:38 PM
scoooby slayer
Originally Posted by markk
Fast that
That's at about 3000 rpm launch rpm so plenty more to come hopefully with more grip mate 👍
Old Aug 20, 2020 | 06:40 PM
markk's Avatar
markk
Launch speed is about the best torque to move the mass with minimal spin. Mine launches at 3500rpm with 0.5bar boost. Any more boost and I get lots of wheelspin and a wasted gear.
Old Aug 20, 2020 | 06:54 PM
scoooby slayer
I spoke to my mapper today about raising launch rpm which he told me how to do but said as it is it's about as good as can be as there's a little wheelspin already, but once I get suspension altered with more squat hopefully will give more grip so I can get the rpm up higher
ive got a sidevideo of rear wheel on launch just need to figure out how to play it back in slow motion to check squat atm
​​​​​​will be easier on some big drag slicks I suppose once I get to that on the 18" rims but want to maximise road spec first 👍
Old Aug 20, 2020 | 07:01 PM
scoooby slayer
Would anyone know how to slow this video down ?
ive been trying and can't do it, just want to see how much the arch squats on takeoff so need to view in slow motion
Old Aug 21, 2020 | 06:51 AM
Rsmat's Avatar
Rsmat
Plenty of slo-mo apps on the phone to play it through mate
Old Aug 21, 2020 | 10:20 PM
stevieturbo's Avatar
stevieturbo
C**t
I used HPC Media player for most, you can slow it down to around 0.13x I think
Or even in Moviemaker it allows you to go down to about 0.25x
https://www.vboxautomotive.co.uk/ind...box-test-suite
Old Aug 21, 2020 | 10:24 PM
stevieturbo
C**t
Just checked, moviemaker goes down to 0.125x
probably a bit too slow though ?
https://www.youtube.com/watch?v=YifB...ature=youtu.be
Old Aug 21, 2020 | 10:55 PM
scoooby slayer
That's perfect cheers buddy 👍
Can see a little squat but it's not much hopefully 12% softer springs will help it, it's got alot of rake aswell back is 20 mm higher than front
And drivers side is approx 7 mm higher than passengers, wondering if I should reduce the rake and corner weight the car once new springs are on 🤔🤔
scoooby slayer
Feb 24, 2020 10:38 PM
Minirotty
20
Mar 30, 2015 04:30 AM
benfiest
Jul 9, 2012 05:50 PM
