Cosworth 4x4 fuel pump priming issue
Hi guys recently if I leave car overnight or so the fuel pump only primes for a fraction of a second and struggles to start from cold, however once started drives and runs perfectly. I’m sure it used to prime for a good few seconds. Any ideas?
cheers Jason
cheers Jason
I know it's not an issue, as I helped restore someones 3 door previously (I repaired the ECU) and that was the same.
When hot mine primes, I find this illogical.
Usually if the CTS were an issue, you would notice it over-fuelling.
Martin
