Ah, just thought with it going to the air intake, wouldn't having warmer air rather than cold air be a negative thing?
What's the best thing to replace it with as mine is splitting due to age.
Its to prevent carb icing. As said a stat opens to allow the airflow via the original ducting. As you say hot air is never a good thing, as it loses density, thus oxygen.
Its only an issue in cold conditions, so I wouldnt worry. Some older cars either had it piped permantely, or an elbow for winter or summer to adjust
on a 1800 cvh you will be better off pulling all that off it and fit performance air filter and give carb a bit sortn out as its a terrible design on them and power is terrible due to all this.. it was designed to be a save fuel thing in 90s
Pretty new to all this. Not sure how I would fit a performance air filter. I changed the standard airfilter just recently as it looked properly beaten up.
Fitting a new performance air filter is fairly straight forward and as said will make a difference to the breathing of the carb and performance. You may find some of the kits come with fitting instructions to help you.
