5if injector ?
there are a few ways, first is a cold start valve injector setup, about 125 quid, the other is more expensive around 300 for a mf2 one, Both needs setting up as with most mods especially anything to do with fuel.
Not sure about a power gain, its also there to provide enough fuel to match with your airflow at a point where the orginal system cant cope, usually high boost cars,
They cut in at a desired level 15psi etc, they provide a good on and off fuel ecomony
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
