Ford focus automatic having issues starting it
Old Jul 15, 2020 | 08:15 PM
Billybobsstuff's Avatar
Billybobsstuff
Default Ford focus automatic having issues starting it
Engine system fault & Transmission malfunction comes up when trying to start but nothing happens can anyone help me please call just won’t turn over can last for 10 minutes 15 minutes
Old Jul 15, 2020 | 08:53 PM
GVK.'s Avatar
GVK.
Can be a number of things but I did have one once that had a broken wire in a connector block on top of the gearbox - thick red wire.
Tried bashing the top of the dash in case its an instrument cluster fault?
Old Jul 16, 2020 | 05:54 AM
oldford's Avatar
oldford
Have the fault codes read from engine and transmission.
That will give you at least an indication where or what the problem is.
Old Jul 16, 2020 | 07:16 PM
GVK.'s Avatar
GVK.
Probably be U codes lack of comms between modules.
Does need checking tho!
tommytwotanks
23
Nov 25, 2011 11:37 AM
gringo43
Jul 23, 2010 10:04 PM
CossieRob
Sep 29, 2006 05:44 PM
