Hello,
I have a left-hand drive 1992 Sierra Ghia 4-door sedan with automatic gear box, with the 2.0l EFI engine (88kw/120HP), and fitted factory A/C (VIN = WF0FXXGBBFMJ45435).
To get the A/C to run again, I need a replacement A/C condensor Type 53143 - Ford OE Nr. 87BG19710AA (see pic below).
Apparently, these are in short supply ... does anyone have a tip or a source where to get one?
I would be very grateful for any leads!
Thank you,
TJ
1992 Ford Sierra A/C Condensor
Reason: updated technical info
