OFAB to Pectel T6 2000M Start Map help
Old Jul 4, 2020 | 03:12 PM
90_spec's Avatar
90_spec
Default OFAB to Pectel T6 2000M Start Map help
Ive finally finished off the engine loom for my Escort RST which is currently running standard OFAB, The Car has an escort T3 and no other mods.
Working in the Motorsport industry i had obtained a pectel SQ6 fairly cheap but have now decided it is way to overkill, luckily a friend gave me a Pectel T6 2000M which i have constructed the loom for.
I have a second inlet manifold with all the sensors connected and calibrated in DescPro, however that is the limit of my knowledge at the moment.
Before i go and fit it to the car, i am hoping someone in the community may have fitted a Pectel T series ECU to a CVH turbo in the past and be able to help with a start map, or a map that will get the engine to idle and drive.
I don't have anyone to live map it yet, but if anyone knows someone that can MAP the old Pectel Descpro stuff, id appreciate a heads up.
The ECU is on Pectel external and i have the correct profile for it.
Thanks in advance
Rich
Old Jul 4, 2020 | 06:43 PM
pectelboy's Avatar
pectelboy
Doesn’t Harvey gibb map the t series ? Sure he maps t2 and t6
Old Jul 5, 2020 | 02:35 PM
90_spec's Avatar
90_spec
I haven't been able to find his website anymore, didn't he used to run specialist car services?
Would be handy as im in Northamptonshire so not far from Peterborough.
Old Jul 5, 2020 | 07:38 PM
GVK.'s Avatar
GVK.
Called Supreme car services now. 01733 576614
https://www.facebook.com/supremecarservices/
boost mad
Oct 25, 2010 01:54 PM
Bart
Jan 17, 2008 10:01 AM
PROMETHEUS
Dec 15, 2007 09:16 PM
sas
Jul 23, 2007 07:35 PM
Spiky
20
Aug 23, 2005 06:10 PM
