3dr Cosworth phase sensor wiring
Old Jun 17, 2020 | 04:22 PM
Rodge.'s Avatar
Rodge.
Default 3dr Cosworth phase sensor wiring
Anyone able to help with this?
Managed to pull the phase sensor multiplug at the distributor off my 3dr Cossie loom. Going to wire it up again but need to know which way round the wires go at the distributor.
There are 2 wires, red/black and green/yellow. There is a "+" mark on the distributor. Which wire goes to which?
I would assume red/black is the positive but thought I'd check
Old Jun 18, 2020 | 05:32 PM
St3V3_C's Avatar
St3V3_C
Wiring diagram links here:
http://www.cosworth.hu/content/haszn...uickchecks.htm
Old Jun 19, 2020 | 09:47 AM
toneee1's Avatar
toneee1
Diagram for you If you still get stuck I have a couple of spare cossie engines so I can look at the dissie for you
Old Jun 19, 2020 | 09:56 AM
toneee1's Avatar
toneee1
Taken from cossie manual
Old Jul 7, 2020 | 05:34 PM
Rodge.'s Avatar
Rodge.
thanks all
mark m
Jan 5, 2015 10:56 PM
ricky
May 20, 2014 07:00 PM
Cosmo
Jul 23, 2009 05:00 PM
petemos
Feb 8, 2009 07:22 PM
NEEDFORSPEED
13
Mar 17, 2008 10:20 PM
