Help please - Turbo loses pressure. Watch video
Old Jun 7, 2020 | 05:23 PM
AlvaroS2's Avatar
AlvaroS2
Default Help please - Turbo loses pressure. Watch video
Hi everybody:
I am Álvaro, from Spain, and I have a S2 cabriolet. It was XR3i but now it has all it can from RST
Turbo Cabriolet
I wirte you cause I have a little big problem with the machine:
When turbo is going to kick, sometimes, it loses pressure (and power fall down), sometimes it doesn.t. It is impossible to get a pattern but i adviced that:
1. It fails more often when it is hot. As hotter more fail.
2. When it fails, engine sound changes to lower sound.
3. I thougt it could be caused by old boost hoses (they was so soft) so I changed to new Rose Motorsport kit. But it continues failing.
You can see a couple of videos. One OK and one failing:
TURBO OK:
TURBO FAIL
Thanks so much, excuse me for my bad English and I hope I could help you in the future.
Old Jun 17, 2020 | 02:05 PM
Rogeyboy's Avatar
Rogeyboy
Its like a slow motion version of the classic, boost spike or peak and hold.
Could be a split or loose boost hose? A restriction in the turbo, air filter etc collapsing? Also i would fit a new wastegate as spring may be weak?
Old Jun 17, 2020 | 09:51 PM
AlvaroS2's Avatar
AlvaroS2
Is it possible it is like slow motion cause I am driving in 4th gear and upping hill? Anyway, I replaced all hoses a few days ago. I think it is possible a weak actuator too. I ordered one last week. I cancelled amal valve and I am waiting for new actuator arrives.
Thanks so much!!
Old Jun 20, 2020 | 07:35 AM
Buster42's Avatar
Buster42
Buenos dias Alvaro I would try an - 31 actuator first because they are the best in my opinion. How old is the actuator on the car now?
Old Jun 21, 2020 | 11:23 AM
AlvaroS2's Avatar
AlvaroS2
Hi Buster. Thanks for your answer. I ordered a -31 one 2 weeks ago. I am waiting for it. I don´t know how old the actuator on the car is, but watching it, I think it is the first and de only one . I hope this was de cause.
Thanks!
rsguy
Sep 18, 2016 10:02 AM
