6 degree beam setup
I’m looking at getting the rear beam and front tracking setup on my 2WD sapphire
im going to do the setup myself with a 4 wheel alignment at a local tyre fitting
the car has
koni shocks
ahmed springs
Polly diff mount
ive already set the wheelbase evenly for front to rear wheel distance
im looking for settings to go by for a road setup
camber & toe etc
many thanks
the car has
koni shocks
ahmed springs
Polly diff mount
camber & toe etc
many thanks
Here you go: personally I prefer a little less meg camber, I think I copied below from an old Mike Rainbird post.[img]blob:https://passionford.com/6100ed33-a7d7-4d9d-bf2d-27046da1a5b4[/img]
Fast road:
Front:
Camber: 1.5° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 1.5° neg
Toe-IN 3mm
Track:
Front:
Camber: 2.5° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 2.0° neg
Toe-IN 3mm
AGGRESSIVE track use - these are the full on Grp A tarmac settings! (can only be achieved with 10mm longer drive shafts and OE steering rack (aftermarket replacement ones use tie rods that are too short and need extension pieces available from Reyland Motorsport to achieve anything more than 1.5° neg camber). This is for use with slicks and track day tyres and is not recommended for road use, will reduce traction in a straight line in the wet :
Front:
Camber: 3.0° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 2° 45' neg
Toe-IN 3mm
Fast road:
Front:
Camber: 1.5° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 1.5° neg
Toe-IN 3mm
Track:
Front:
Camber: 2.5° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 2.0° neg
Toe-IN 3mm
Front:
Camber: 3.0° neg
Caster: 3°30'
Toe-IN: 2mm
Rear:
Camber: 2° 45' neg
Toe-IN 3mm
coachworz
Mar 19, 2008 11:02 PM
Spiky
18
Aug 30, 2007 11:06 PM
