Cosworth starter motor
Hi All,
The starter motor on my 93K plate 4x4 Sapphire has just decided it wants to give up.
Ive heard Transit Connect 1.9tdi 2008 starters fit Cossies, do they fit 4x4 as well?
Has anyone done this?
Apparently the only different between the 2wd starter and 4x4 is you have to drill the threads out on the 4x4 starter as its the gearbox side thats threaded, where as on a 2wd the gearbox has clear holes and screws into starter, so you can still use the transit starter and just drill the holes
markk
15
Aug 15, 2014 11:44 AM
