Warning lights
Old May 12, 2020 | 08:41 AM
rondetto's Avatar
rondetto
10 Year Member
Default Warning lights
HI, I have a Ford B Max Titanium. I have a warning light coming on all the while which in the manual it says to check the tyre pressures.
I've done that and the pressure is fine, does anyone know how to turn this warning light off?
Thanks for any replies.
Old May 12, 2020 | 02:06 PM
GVK.'s Avatar
GVK.
Does it not tell you in the manual how to reset it?
Old May 12, 2020 | 03:13 PM
rondetto's Avatar
rondetto
10 Year Member
Thanks for your reply. All it says is to contact your local Ford dealer. But they'been closed since March and no signs of them opening soon.
I was hoping someone might know how to turn it off.
Old May 12, 2020 | 04:52 PM
St3V3_C's Avatar
St3V3_C
We had this on the Tourneo. There is a process to reset it, have a google.
Old May 12, 2020 | 05:25 PM
rondetto's Avatar
rondetto
10 Year Member
Thanks for that, I'm in lockdown so I will go out and try what I've just learnt on You Tube. God bless You Tube eh?
Old May 13, 2020 | 04:46 PM
DangerousBryan's Avatar
DangerousBryan
You reset it in the audio screen. Under the menu,vehicle tab.
Old May 13, 2020 | 04:49 PM
rondetto's Avatar
rondetto
10 Year Member
Thanks to both, I have done it now and all is fine. Marvelous what you can learn eh? Can you do similar with the oil change light?
Even If I check the oil and service the car the warning lights come on to say a service is due and an oil change.
hairyford
Ford Fiesta
Jun 21, 2018 05:41 PM
karl125
Ford Escort RS Cosworth
May 2, 2007 08:11 PM
RST Ski
Jan 1, 2007 11:03 PM
milliondtm
Nov 7, 2004 08:31 PM
