Just took off the Dump Valve :)
Just got my dump valve bung through off ebay (It was off a guy on here, sorry cant remember name) and fitted it, blocked off the vacuum hose with a screw for now and took it out for a drive!
Let it warm up and it feels sooooo much smoother and when I change gear I get a little bit of chatter!
Fitting the K&N later so maybe this will make the chatter sound a bit louder
Its much nicer to drive too but it does feel wierd not hearing the noise when I change gear!
I think it was about 4 quid....less than a tenner including delivery
Looks a bit shinier than a broom handle
Mine is running about 15-17 psi so you can hear it a bit, with a K&N will it make much diff?
Originally Posted by Little Joe
Well done Rodney.
Cannot wait for K&N now, chatter is addictive
So I am Rodney and Lofty
Tiff and Joe you pair of bumlovers!
Originally Posted by SPADGE
I can't believe you can really feel any difference with it or without it
Spadgeroo, no DV required AT ALL on an RST (KEJet) - in fact the fitment of ones causes problems which then have to engineered out = don't bother fitting one in the first place
Do you really not notice a difference between a DV'd car and one without? (Sub T4 turbos anyways)??
.Do you really not notice a difference between a DV'd car and one without? (Sub T4 turbos anyways)??
Originally Posted by TIFF-C20WTH
Spadge
They are on about Beantins
But deffo not required on a normalish engined/turbo'd BEANTIN!! Unless you're a bus driver and miss the sound of your air brakes
Spadge
Spadge
Originally Posted by Westy
taxi pleeeaaaassseee... or Mr cornershop's daily driver
at least bean tins look good... a Saff just looks like your everday 200 quid shitter saff... OOOOooooooooo !!!
Ohhh dear god did you just say bean tins look good
When you get to my age (barring the odd mistake) you would have aquired some taste i hope
At least with a saff you have the performance which can make you ignore the dull looks
S1 & 2's are sexy
and you know it.. thats why you just had to have one..
Anyway, if your near or at Anglo's on monday, feel free to pop in and stroke a sexy S2
Your mates doing a blinding deal on me car.. Im well happy
and you know it.. thats why you just had to have one.. Anyway, if your near or at Anglo's on monday, feel free to pop in and stroke a sexy S2
S1 & 2's are sexy
I'll pop down Monday and give it a few extra strokes with a hammer
spadge, KEJET is a metered air system... the metering head needs to "know" about every last little bit of air...
you let metered air out of the dumpvalve instead of letting it get into the engine, and you're asking for running problems
Originally Posted by digita1dragon
Originally Posted by Turbo lag
Goodbye turbo
Poom, good work pal! Mine makes loads of noise! due to having a bigger IC I expect.
Will be getting a GRS or Pro Alloy soon though bread bin
