Bleeding brakes if you have a brake bias setup
I have a tilton brake bias lever on my mk3 fiesta track car. I'm thinking of bleeding the brakes as they are starting to feel spongy. Do I have to do or consider anything different because of the brake bias setup or can I bleed the brakes as normal?
wilwood 4 pot at fronts and cossie discs on rear.
Thanks.
Thanks.
Gra
Jan 16, 2005 03:53 PM
