Swap 1.8 tdci in Mondeo Mk2
Old May 2, 2020 | 10:29 PM
Pablo Brancato's Avatar
Pablo Brancato
Brancap
Default Swap 1.8 tdci in Mondeo Mk2
Hi All,
I was just wondering, Does anyone has any experience swapping a 1.8TDCI focus engine into a mondeo mk2 TD?
Imagine starting from a complete 2004/05 donor Focus with all the engine wiring harnesses and the ecu. And maybe to make it easier, leave in the Mondeo the original gearbox to avoid problems with axles and mounts.
At a glance both engines seem to be externally similar except for the intake with upper intercooler in the Mondeo.
I was thinking about that because in my country there are many Mondeos TD broken and repair them is costly. And there are many Focus in junkyards because it was locally manufactured.
And tdci has more power and less fuel consumption.
What do you think? Thanks for your opinions.
Old May 3, 2020 | 06:56 AM
oldford's Avatar
oldford
The question you should be asking is: will the engine controller of the Focus communicate with the older Mondeo?
And will the older Mondeo computers react to the signals of the newer Focus controller?
Otherwise you get problems with Abs and Instrument panel.
Old May 7, 2020 | 01:57 AM
Pablo Brancato
Brancap
Thanks oldford. I didn´t even thought about instrument panel and ABS.
Seems to be not so easy as I innitialy thought.
Mr.Ford
Aug 12, 2010 05:52 AM
amsie
Ford Focus RS
Aug 13, 2009 02:08 PM
Oranoco
29
Oct 22, 2006 05:23 PM
graemewelch
12
Jan 15, 2006 09:38 PM
